SoundGuy
Feb 27, 2016Explorer
Jonathonchisum wrote:
I'm not an electrician so I was just thinking of replacing the whole thing inverter and all.
Converter, not inverter. ;)
It's difficult at best to diagnose without actually laying eyes on a situation but my guess would be that your converter is failing and caused the resettable circuit breaker that is wired to the positive terminal of your battery to open, in which case there'd be no power being supplied by the battery and no power from the (presumably failed) converter. These are auto retting CBs so it's not surprising it may have later reset once it cooled down, allowing the battery to once again power the trailer. As for the 120 vac circuits, keep in mind that the converter has no bearing on those circuits - the fact that the breakers for these circuits are mounted on the converter's front panel is merely a matter of convenience - i.e. the converter could be completely toast yet the 120 vac would still work. My suggestion - since you've said yourself you're "not an electrician" you'd be wise to have a dealer tech who is qualified take a look as you could easily make this situation far worse by not knowing what you're doing.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
