phemens
Nov 08, 2020Explorer
With Lithium you should only be concerned with charging after the thermal mass of the batteries has dropped below the minimum mfg recommended temp - there is no issue with discharging lithiums in cold weather, in fact they generally outperform other technologies in that scenario. For me that's roughly 0C, so I set the limit at 5C to be safe. I installed a waste tank heating pad taped to an aluminum sheet and put that under the batteries. Kicks in at 5C and turns off at 12C, without intervention, but I put in a cutoff switch for warmer weather anyways. Draws about 6 amps per hr. Victron monitor and temp sensor give accurate reading on battery temp and prevent solar from charging below 5C. I am completely off grid and it works great.
