Steve92004's avatar
Steve92004
TV Question
I want to replace the little tv/dvd combo in my toy hauler
I heard some standard led tv's use a power adapter and that many are 12v and they plug them directly to 12 volts
I also heard that if you use a 120 volt tv you would have to use the generator whenever you watch tv.
Can it just run off the inverter?
I also want to get one of those portable directv tripod dish and take my directv receiver with me so I can watch the football games
How are you guys doing it?
Thanks!
  • We have a pathway X2 and a 211 receiver and a 45" sony tv in the main room. All run off our inverter without problems.
    In the bedroom, we have a 211 receiver and a 32" sony tv and run it off our portable inverter (through a 'car plug' rather than direct wired) with no problems. The inverter is a 300W pure sine and the 211 and TV only pull about 80W combined. We use this to save battery as we have other stuff connected to the house inverter. We need to conserve the batteries at night to make coffee in the morning...
    We only have to use the generator to watch TV if our batteries are less than 50%, which never happens because we have solar.
    I have had to camp near people who believe they need a generator to watch TV. In both cases, they had a 5K open frame construction generator. They ran it for HOURS just to power 300W worth of tv.
  • Some LED TV's use a "power brick" that plugs into the wall and converts the electric to 12 volts. If you can find one like that, you can wire it directly to 12 volts. I have a small, cheap, 13" set that works that way. Unfortunately, those kinds of TV's are few and far between.
    Using an inverter to power up both the TV and satellite system is an option. You just have to make sure the inverter is rated for the maximum load, and based on the size of the inverter, you have enough batteries to last a reasonable amount of time.
    I have heard that it is not too expensive to take a Direct TV receiver from home to use in the trailer, and depending on the receivers you have, there is probably a portable dish that will work - get the make and model number of the receiver you want to use, then check out the dishes you like.
    We use a stand alone Dish TV system that uses a Wingard Pathway X@ dish and a 211 series receiver - works great, but have to have shore power .....
Having RV issues? Connect with others who have been in your shoes.24,347 PostsLatest Activity: Jan 10, 2026
