MudChucker
May 21, 2017Explorer
TenOC wrote:
I do not understand the problem. My TV charges my TT battaries when it is connected and the switch is on that is the truck is running. I assume the 5er does the same. Check your 7 pin plug. Pin #4 should be the 12 volt charging and pin # 2 should be ground.
RV pin wiring
while it is true that you are pumping a few amps down that wire into the plug, you really arent charging too much while you are driving.
depending on the loads in the camper itself you are likely only carrying enough so as not to be discharging while driving.
this may be enough for you, and has been for us but now as we boondock more and plug in less.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
