MrWizard
May 21, 2017Moderator
MudChucker
gadgets or NO gadgets, your batteries should be charging
are you running the fridge on battery power ? instead of LP
perhaps the fridge is running on inverter sucking down the batteries
while I agree solar will help
you need to find out why, you are sucking down the batteries while driving
what is wrong with the current charge system, or power OVER USE
FIX that then increase the charge going to the batteries, with new wire, solar etc..
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
