MudChucker
May 22, 2017Explorer
theoldwizard1 wrote:RoyB wrote:
Using a multimeter you you can tell by just measuring across the batteries terminals without the motor running and if the batteries are at 100 percent charge they will read 12.6-7VDC. Then turn your ignition on and start the motor. If the path for charging the batteries is good then you will see the DC Voltage across the battery terminals jump up to 13.6VDC or higher depending what your truck alternator setup is doing...
THIS TOPIC HAS BEEN COVERED A NUMBER OF TIMES !
First, 13.6V will NOT come close to fully charging a deep cycle battery that is at 50 percent state of discharge. Even 14.0V won't do the job ! Sure, if 13.6V is maintained it will not DISCHARGE further.
The short answer is, for "modern" (past 10-15 years) TV, YOU CAN"T GET THERE FROM HERE ! Modern vehicles use "smart charging" systems where the charging voltage will drop off to less than 14.0V shortly after the engine starts. 1/0 wire is not going to help this !
You need a DC-DC charger that will handle low (down to about 10V) input voltage. They exist, but none that I can personally recommend.
Thanks for that, thinking that solar might be the best solution...or mount the geny on the rear bumper and run the generator while we are underway.
Either way, i knkw that i have power on the 7 pin plug, but the loads in the camper suck that juice up leavimg very little to store in the trojans.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
