time2roll
May 22, 2017Nomad
Truck should provide 5 to 10 amps without too much trouble. Basic trailer running the fridge on propane should draw one amp or less. This would seem to indicate an issue with the charge circuit from the truck. May not come close to fully charging the battery but certainly should run the basics and provide some charge. Clamp-on ammeter might be needed to discover where the power is going. Could also be an intermittent issue while in motion.
Still since you camp off-grid I think you will benefit from solar.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
