MEXICOWANDERER
Aug 12, 2015Explorer
Ooooo the diagram is to control load switching. Like a SALESMAN switch only this thing cuts off the whole she-bang. The two-battery diagram is for convenience only. Salesman switches done right need only one battery as solid state only need 3 volts to switch. I've seen sixty ampere versions of this relay so if common sense is used sizing relays for high loads a TRUE inside the coach total and complete isolation hotel shutdown is possible. I still would use a genuine heavy-duty switch and 16-gauge cross-link wire to trigger the relay. Adel clamp the heck out of the black nylon spiral wrap that would protect the wire.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
