Wankel7's avatar
Wankel7
Underperforming Dometic Fridge...
My 3 year old Dometic RM2551 (5 Cubic foot model) isn't cooling well enough on propane. Unable to test in AC. Creeps up to 50f inside ...90F outside. Running an internal and external DC fan. Cleaned the orifice and burner tube. Flame looks great and the camper is level. Side vent and roof vent clear.
When I turned it on the first day after 5 months of storage it was 32F inside for 24 hours. Then it started slipping to 50F.
Ohm checked the thermistor and it passed.
I am stumped.
Picture of the flame.
https://1drv.ms/u/s!AoCNkn5aOOMYwyGUMDKRnORL7Tu6
  • Wankel7 wrote:
    The tubing that runs up the fridge backside is black with dust.
    There shouldn't be any dust on the coils, except maybe for plain old road dirt. Post a picture.
  • 2oldman wrote:
    Any yellow or green powder on the coils?
    That is a great idea. I read about the limp mode when the thermomister is unplugged. I will do that !
    I used my temp gun and get 0F to -4F in the freezer. What is normal for the freezer ? Temp gun shows around 50F on the fins in the fridge.
    The thermomister is on the furthest right fin middle of the fin. The clamp makes it difficult to put on any other fin.
  • The flame looks good...Blue and reaching just up into the bottom of flue center.
    Need to check thermistor/temp controls by unplugging thermistor from lower circuit board and let fridge run for 12 hrs.
    Fridge should run continuously and dang near freeze items in food compartment
    Thermistor leads plug into P2 2 pin connector on left upper area
    If fridge cools down with thermistor unplugged then replace thermistor
    (even though it Ohm OK)
    IF fridge does not cool down then you have a ventilation, airflow/draft or bad cooling unit problem
    What FIN do you have thermistor on and where on fin is it?
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 23, 2025
