johnm1's avatar
johnm1
Understanding battery usage and capacity
Sometimes I get a brain fart and just can't get out of my own way.
What does battery AH ratings vs usage mean?
I have (2) 6vdc gf batteries with 230ah each which means I have 230ah's to use if I drain them to ... 50%. How long does that "last"? I know, VERY user dependent.
If I run the following scenario, it seems like I don't have nearly enough battery but yet I can get by for a couple of days without recharging ... at least I did last year.
-------------What-------------------VDC--Amps--Watts--Hrs/day--AH
Propane detector (& phantom loads)--12--0.30--3.60----24-------86.40
Radio-------------------------------12--1.00--12.00----2-------24.00
Fridge (w/o cooling fans running)---12--0.90--10.80---12------129.60
Main lighting-----------------------12--1.61--19.27----3-------57.82
Main awning light-------------------12--1.41--16.86----3-------50.58
1 puck light------------------------12--0.60--7.20-----3-------21.60
Fantastic Fan #1: 50%---------------12--0.75--9.00-----6-------54.00
Fantastic Fan #2: 50%---------------12--0.75--9.00-----6-------54.00
Water pump--------------------------12--8.50--102.00---1------102.00
Water heater - Heating--------------12--0.85--10.20----3-------30.60
-------------------------------------------------------AH/day 610.60--(should be ~51AH/day
The AH/day should be ~51 (I multiplied W*hrs to get AH ... like I said, brain fart)
- I know the above devices are 12vdc
- I got actual amp readings from the RV
- To go from A to W, I used ... Vdc * A = W
- I guessed on hrs/day but it's probably not too far off
- I guessed on fridge cycle duty as I have no idea how often it turns on and off and it does have 2 muffin fans for external cooling
I'm trying to figure out what my next electrical system upgrade should be (ex: should get 2 more 6v gf batteries?) but this just isn't making any sense.
Thanks,
John
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
