dougrainer
Jul 13, 2020Nomad
theoldwizard1 wrote:wa8yxm wrote:
Well that looks like one of the MOLEX products but that is a company name and they make over a thousand different connector.. many made to a company's specs
I would change the connector to something more common (there are many options) provided you can find the dome light that can use the same connector.
Concur !
Nothing inherently wrong with Molex connectors, except as stated there are thousands of different ones.
It sure would be if the world could standardize and a robust 12VDC connector. Cigarette light sockets and plugs are too big and not really a durable design. The automotive solution from years ago was pretty good, but it was not polarized so it was possible to reverse polarity ! :E Powerpoles are not perfect because it is still possible to reverse polarity, but at least they are color coded.
The OP's type connection. HOW could you connect in reverse polarity? The Spades are D shaped and you can only install 1 way. Doug
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
