Tom_M1
Jul 13, 2020Explorer
time2roll wrote:Powerpole connectors come in two series, PP and SB. The PP series are not keyed so different colors can be connected together. The PP series are typically used in pairs such as red and black. Each connector has a dovetail which will slide together with the mate. A roll pin is then inserted to prevent them from sliding apart. Once paired the polarity can not be reversed.
+1 for power poles. No polarity issues here. I see two screws in the OP picture... feel free to use those to install something else.
I believe colored connectors mentioned above are for Anderson connectors to separate odd voltages if needed. Only same colors will connect. So pick a different color for 24 or 48 volt set up to avoid confusion.
The SB series is a two contact connector. They do have a key and each color is keyed differently. Different colors can not be connected together.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
