ajriding's avatar
ajriding
Explorer II
May 27, 2019
Unplug All The Charger/Converters
Recently saw a video from a good mechanic.
On the vehicle of newer cars n trucks a lot of things are electronic and even wireless (like the key)vehicle.
Issues can occur. Electronic noise can interfere with the vehicle computer system.
Sometimes it is the little DC plug phone chargers and cheap-o inverters even that can wreak havoc on the electrical system. It is usually the very cheap/low-priced phone charger plugs (in the $1-$5 range), not the high quality $25 ones.
If you have issues, if you cannot start the vehicle, then just unplug all those lil rascals and try again.
Better yet, he concluded, is to use a nice inverter wired directly to the battery and power your devices off that since it can produce clean power. An inverter turns DC power to AC (household) power, but should nowadays have DC USB outlets in it also.
No discussion necessary as this is not an opinion piece, just information to keep in your noggin in case you have vehicle issues and a lot plugged in
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
