I have a small Klein Tool Tester that is showing "Hot/Neu. Reverse" when plugged into a nearby outlet. Would this outlet be safe to use for a couple of hours? Thanks in advance for any input....RT 210
Yes, you could use it for a short period. Is your rig equipped with 30 amp shore power or 20 amp? If 30 amp, are you connecting to a location that has both and are you testing the 15/20 amp receptacle and not the 30/ You could use your Klein tester with 30 amp adapter to test the 30 amp.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
