I have a small Klein Tool Tester that is showing "Hot/Neu. Reverse" when plugged into a nearby outlet. Would this outlet be safe to use for a couple of hours? Thanks in advance for any input....RT 210
Fix it before use. If you do not have permission to fix it, make up a 'gender bender' cord where hot and neutral are deliberately reversed. Mark both ends of the gender bender with red tape to make sure no one uses it by accident. Label it hot and neutral swapped.
