ve7prt's avatar
ve7prt
Unusual Incident With Honda EU2000 Eco Throttle
Hey All,
So we're camping at Rathtrevor Provincial Park this past weekend and Saturday afternoon I notice on the XBM that the battery bank is getting down, and should be given a boosting charge. So, at 6pm I fire up Lil Red, hook up the trailer, and energize the charger (PD9280) in BOOST mode. I also switch the fridge over to the shorepower and kill the inverter. Generator is happily spewing out 110VAC to the trailer, running at around 50% RPM.
A few minutes later, the unit starts revving up and down. I had heard the fridge kick in (made the genny really work hard for a moment), but the main load is the charger. Looking at the XBM I see the current flow into the battery bank matching the genny's RPM's. RPM's go up and current flow increases. RPM's go down, current flow decreases. Average current at this point is around 65Amps. That's a little low.:?
So, I go flip off the Eco Throttle. Lil Red quickly spins up to full RPM. A further check of the XBM shows the current flow now at 78Amps.
I turn the Eco back on, genny slows to 50%, give or take. Couple minutes later, she starts revving up and down again. :h:h Charge current again follows the RPMs. I tried a space heater on LOW to give a constant load, thinking the charger may have been having an issue, but that added load was a bit much for the genset (didn't pop the breaker, but I could tell from the sound she wasn't happy).:E
I ended up the running Lil Red the entire hour with the Eco Throttle turned off. Made for a somewhat noisy hour. I've never seen this behaviour before in this unit; she's always purred along at a constant RPM with the charger working.
The only change I am aware of is I plugged into the right side outlet rather than the left side outlet. When I had the truck at the dealer in the morning, they washed the truck with the genset still in the back. So I'm wondering if either using the right side outlet caused the ET system to have issues tracking the load or if water got somewhere it shouldn't have.:S
Also wondering if anyone else has seen this issue.
Cheers!
Mike
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
