pugslyyy
Aug 11, 2013Explorer
Lynnmor wrote:
My brake drums are out of balance by 5.5 oz. The tire/wheel assembly is out by 2 oz. Please explain how 3 oz. of beads will correct this balance, and at what speed.
How are you using tire weights to balance your brake drums currently?
As a practical matter if I was getting bad vibration at a corner and thought it was due to brake drums and I was using beads I would try rotating the wheel 180 degrees on the hub so that the out of balances counteract each other.
At least until I could get the brake drums turned and balanced.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
