BFL13
May 05, 2017Explorer II
-Lqdskier wrote:
That sounds like a great option, Bobbo. Do I need any additional components or is the kit complete? I pretty sure mine is the 6300 series.
You need to "jumper" the 6300's fuse panel to use it with a newer converter, or you can buy a new fuse panel that works with the 7300 or others.
Beware of the upgrade kits 7300R and Ultra which get you a 7300 or a WFCO (unsat) You can get an upgrade using PowerMax or PD for less money and have a way better converter.
I disagree with Bobbo and the 7300. Works great as a shore power converter and ours has lasted years and years (2002 built rig) I use different chargers for fast charging with generator power off grid though. Single 13.8v from the 7300 is not enough for that job.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
