Polch's avatar
Polch
Upgraded and relocated analog to digital thermostat was working and Now not working.
I was putting the wires back into the wall wire nut it everything and it just stopped working the lights went Out on it no more numbers tried to find a reset I'm going to test the wiring and see if it's still hot but it was a little while ago
  • ok so I am taking a guess you are talking about a normal thermostat for just a furnace? and that you bought one for a 12 or 24V setup.  if it is wired right and there is batteries in the thermostat it should work, as long as it is a simple 12V loop and only 2 wire setup.  you second post I am not sure what your trying to say to be honest.
  • Update:: When to red wires and the 1 from the thermostat shut down past the connection
