myredracer
Sep 28, 2015Explorer II
Huntindog wrote:
I seriously doubt that the frame is responsible for it. Most of it is due to the LOOSE tolerances in the springs and shackles. That is as it is designed. And yes I have had axles out and installed quite a few sets.
But it is apparent that you have made up your mind on what the issue is... I hope you are satisfied with whatever the result turns out to be.
Over and out.
I lashed a camcorder under the TT in the above photo. It was very surprising to watch the spring hangers flop left and right like a pendulum every time I turned a sharp corner. That was over 2 years ago. I if I can find it, I'll post it one day. There's things about the welded 3-piece frame that I just cannot get into detail on for reasons I cannot get into... I know there are some that have ended up with cracks in the vertical web of these beams just above the spring hangers due to the amount of left/right flexing in the frame and hangers that goes on.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
