myredracer's avatar
myredracer
Explorer II
Sep 28, 2015
Upper shock mount broke clear off. Flippin' unbelievable!
Could have killed us:
We had Monroe shock absorbers installed on our TT care of our dealer when we got it new in April of 2014. The dealer insisted they take care of it so they sent it down the street to a suspension shop.
I handed over the shocks, lower mounting brackets, bolts and flat bar for the upper mounting brackets. All they had to do was the install and some welding. I made up a very detailed drawing showing EXACTLY how I wanted it installed. I showed the upper brackets to have 45 degree chamfers for max. weld penetration onto the beam surfaces. Seems like they totally ignored the drawing. With out going into a lot of details, they really botched the work and I went back TWICE again to try and get it taken care of but they refused in the end. The dealer (who we paid directly for the work) refused to have anything to do with it. So from the beginning I was NOT happy.
We just finished a 2500 mile trip through the Oregon Cascades from the Or/Wa border south into Ca. and on into Reno. Drove on a lot of highway sections with many twists and turns at speeds up to 60-65 mph. Numerous sheer drop-offs on one side too. Many downhill runs at up to 9% grade often with corners at the bottom to get around. A blowout on a tire could have been potentially deadly if it happened at 60+ mph, on a steep downhill descent, round a corner. Add a sheer drop-off and it gives me chills.
Got back on Friday and today I was looking underneath to check that all was okay. It's not. The upper mount from one of the shocks came clear off the I-beam it was welded to (or supposed to be welded to) - photo 1. The shock was obviously flopping around as the flared edge at the bottom of the upper half of the shock tube was rubbing against the tire and cut a sharp groove in the tire. Tire is now history. Photo 2 shows how the bracket is supposed to be positioned. I had specified that the 3" x 3/16" plate be welded to the top and bottom flanges of the beam. I can only surmise this happened closer to home.
I also wonder if the shock did not stay in the upright position and was flopping around what might have happened. Or if a blowout happened and the shock was flying around whacking things. Maybe might have been a lot of damage from flying rubber and other debris.
In looking closer at the broken bracket (last photo), there is NO weld material at all on the flange of the I-beam. They just did a butt joint with a surface weld instead of a chamfer that I asked for. Two of the other brackets have failed lower welds and I assume the 4th is no good with close inspection and maybe some dye.
I just don't don't know what to say at this point. Just glad we made it home okay. I even made mention of the shop in a post in another thread yesterday about how bad they were.
Will be interesting to see what the dealer says. It has nothing to do with the manufacturer, KZ (we have a 2 year warranty). We paid the dealer for the work and they insisted on the particular shop. We did not hire the suspension shop. It's one of those things that could even end up in court I suppose. I am totally pi**ed. I could even have done this myself with my MIG welder and done a good job or I know a mobile welder that could have done it too.
Maybe I'll just take up flying a small plane instead of RV-ing. Safer, cheaper and less aggravation.
  • :h
    That plate was not needed.
    You could have totally avoided that mess if you would have had the shock directly mounted to the frame.
    I would have drilled the frame, added a plate on both sides of the frame to add some reinforcement for the hole. Then you could have simply bolted the shock directly to the frame (with a couple of spacers to hold the shock away from the frame).
    Welding can actually alter the strength of the steel anyways so a hole with added reinforcement would not have caused any problems for strength..
    That setup was doomed to failure since it relied strictly on the top and bottom welds on one side.. It really needed a side gusset(s) to add more welding surface..
  • I'm confused. Was this a repair on a new TT? Or was was this an owner modification to a new TT that was supposed to work? If this was an owner mod probably a good thing you didn't inform yor insurance co. I tried to modify a MH suspension back in the 80s. A spring co. wouldn't even touch the problem. Too much liability involved.
  • Sounds like you wanted to upgrade the suspension system. So you handed them shocks and some drawing for what they need to do. But, why? What was wrong with the stock suspension system? Had you left it alone, you would not be in this mess.
  • When somone is supposed to do a critical weld I insist
    ALLSTATE 275
    Be used. Nothing else. Stick reverse DC rod.
    200,000 PSI and it's easy to use.
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 04, 2025
