mrekim
Jun 21, 2014Explorer
Thank you for performing this test and sharing the results. These results are encouraging.
Is your tri-fuel setup a modified carb or does it have an adapter between the carb and the air filter?
[edit]
Also, when on propane, does the generator work fine in fuel saving mode where it idles down with a smaller load when the power needs are less?
[/edit]
[edit]
[/edit]
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 26, 2026
