Wayne_Dohnal
Jun 21, 2014Explorer
Is your tri-fuel setup a modified carb or does it have an adapter between the carb and the air filter?
I have the modfied carb setup. Did it myself using the instructions from the Yahoo eu2000i group. AFAIK it's identical to the Central Marine Diesel conversion, using the same regulator.
Also, when on propane, does the generator work fine in fuel saving mode where it idles down with a smaller load when the power needs are less?
Mostly yes. When I adjust the mixture to optimize for maximum power, it idles roughly. It runs at the proper idle speed but is running rich. If I lean the mixture for smooth idle, it won't develop maximum power. I've read a few reports in the past that said this works perfectly. I'm wondering if this could be caused by my 3,500 foot altitude?
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 26, 2026
