briandunning1's avatar
Jun 09, 2018
USB adapters make a whining noise?????
This one is too many for me... I have a 12V socket in my RV for recharging phones and stuff. Any USB adapter I plug into it makes a whining sound, which someone once told me was a bad capacitor. They still charge OK though. The same USB adapters work fine in a car with no whining sound -- I have tried all three that I have. Any thoughts? Could I have some weird current or voltage problem?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I agree with the "Turn off converter" suggestion.
    Even with 15 volts in they should be silent. A Hissing sound is often the reslut of a failing connection somewhere.
  • MrWizard wrote:
    Your house 12v is close to 15v or above
    You have an A.C. Voltage ripple in your house 12vdc
    Meaning your converter is failing
    Easy to check - just turn off the converter and run off the battery, if the noise disappears then the converter is likely the culprit.
  • Interestingly a few weeks ago I noticed an ever so slight squealing sound in the camper and eventually discovered it was the plug in USB charger shown at the bottom of this pic ...
    I just replaced it with another and it's fine so I'm sure it was just the unit itself and had nothing to do with the trailer. Chinese factories are pumping these things out by the billions every year for pennies apiece so the fact this one happened to start squealing didn't surprise me at all.
  • Two guess
    Test with multi-meter on the lowest ac voyage setting
    Test at the 12v socket
  • I would check the polarity of the receptacle.
    The shell should be negative and the center pin is positive.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
