JimBollman
Feb 16, 2014Explorer
I have the Blue Seas USB Plug also and love it. I mounted it near the bed so if I want to use my iPhone to read in bed I can be charging it. You don't need any special box or anything just drill the right size hole and run large enough wires. The current 12 volt plug probably has large enough wire, the Blue Seas is rated a max of 2.1 amps at 5 volts. You don't need to use the square mounting flange if you drill the right size hole.
