theoldwizard1
Aug 06, 2018Explorer II
If you have severe corrosion, what I call the green crusties, apply D100 an let it soak for about 24 hours. You might need to repeat this a couple of time during that period.
Open the circuit breaker to the outlet, and use a generous amount of brake cleaner to "blast" out the green stuff. Brake clean will dry in minutes. Reapply D100.
As said before, this will NOT fix worn or weak springs in/on the actual contact.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
