FSAD's avatar
FSAD
Use onboard Onan to power house in emergency?
So I was thinking, hey, I got a fancy schmancy Onan, built right into the camper, so why would I need to buy some portable unit to run various things in the house during an emergency?!
So I grab my 20A 50' cord, thinking I'll just fire up the genny and plug the ext cord into the outlet on the outside of the camper, run it into the house and feed a few things off a decent powerstrip with individual cords.
Then I got to thinking.... Sure that all SOUNDS like it would work, but would it? Here's why I question it.
Running a 20A cord from the "genny" to the house is good enough to power multiple other individual cords, but the outlet on the camper, I'M GUESSING, is a measly 14 ga. going back to the genny output. Hence, I would not be really running a 20A cord from the genny!
right?
So, can I tap into the genny somewhere else that I can wire up an additional outside plug on the camper that is truly heavy enough to run my ext cord that will then feed all the little other cords in the house?
I'm not an electrician (obviously, that's why I'm asking) but I have the mechanical ability to do such a mod, and believe that I COULD have an issue if I try to power too much stuff off the ext cord, since the outlet back to the genny is most likely wired with smaller gage wire, I'm sure.
thanks!
mikey
