jomarex
Nov 24, 2015Explorer
So, I could set the 2nd battery on the platform (that's already on the back of the RV), hook it up to the inverter with the two thick cables (and a fuse), plug the RV power cord into the inverter? (with an adapter plug to take the 30-amp RV plug down to the "regular" outlet on the inverter?)
I'll assume for now that 400 watts worth of solar panels in the Texas sun :) will be enough to power the inverter and then through the converter to the other battery, if I'm visualizing this correctly.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
