wa8yxm
May 17, 2014Explorer III
teddyu wrote:
I don't believe it will "condition" the power, but it will typically work for low & high voltages, open neutrals and grounds, and surges. JM2ยข...
There are two types of Surge Guards... And your statement is correct for the good ones. (More after I answer the Original Poster's question)
To the Original poster: The answer is YES, not only will it work, but one if it's functions will work BETTER on a smaller power feed..
Now to both: Low cost "Surge guards" are simply spike supressors. they are little more than MOV (metal Oxide Varisistors) and do a very good job of clipping spikes that come along when say an air compressor cuts out.... I do not recommend these though because they do NOT perform the 2nd function... THIS is, however, the function that a 50 amp unit does better.
A true Power Guardian type Surge Guard. Monitors voltage (HIGH/LOW) and possibly Frequency and sometimes waveform.... These are the ones I recommend.. They also perform the first function (Spike Suppression) as well. They monitor for things like open neutral/ground/reversed polarity and such along the way.
They are also more expensive.
But even this fucntion is done better by the bigger unit (Bigger contacts on the relays)
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
