berreez's avatar
berreez
Using a infrared thermometer gun
Got a question; I’ve loaded up my 37’ Class A and took it over some scales. I inflated the tires to the appropriate tire pressure for the 235/80R22.5 LRG tires.
What would a safe operating temperature using an infrared thermometer gun when I check them during a gas stop?
  • Bobbo's avatar
    Bobbo
    Explorer III
    Check them all. If they are all about the same temp, you are good. If one is appreciably hotter than the others, you have a problem.
  • Like it was said by another, the thing to watch for s the odd one.
  • I have seen as high as 130 in the dessert.
    I saw 160 once when there was grease on the brakes.
  • Temps will vary a LOT depending on speed and ambient temps. I've seen 150+ but 120ish is typical. What you are looking for with temps is the outlier. One tire much hotter than the rest. Ten degrees variation is common. Inside duals run a bit warmer than outside. Sunny side runs warmer than shaded side. On a crowned road the right side will run a bit warmer too.
  • On an Arizona 4th of July I guarantee the reading will lighten your foot. Yet tires endure 160F pavement. Be aware of inequality especially with inner tires. Shoot the bearing caps on the front if you can see them.
  • My tires have usually run at around 110/120. 275/65 R15 LR-D
