Desert_Captain
Jul 17, 2022Explorer III
Gdetrailer is correct. The key to a swamp/evaporative cooler is having the right/conducive environment. At this moment it is 103 outside with 25 percent humidity. My swamp cooler in our 1,400 square foot home is cranking on high and delivering 24 degrees of cooling for a very pleasant 79. I should note that once the temp rises much above 101 - 103 the efficiency will fall as it will if the humidity is greater than 30 percent and less is better.
Most RV AC systems struggle to give you 20 degrees of cooling and few if any will give the 24 - 25 degrees I routinely get from the swamp cooler. The problem that I see is they are hardly adaptable to an RV unless it is permanently parked. Coolers are by necessity fairly bulky, need a steady albeit light stream of water to replace the water lost to evaporation as the rest of the water just recirculates via an AC driven pump, ours is a one half HP model that draws very little current rendering it very cost effective.
When riding motorcycles here in Arizona in the summer we utilize so called wet vests which effectively are portable swamp coolers. You soak the vest completely in the coolest water available and as you ride the evaporation is very effective at cooling your core. Riding in 100+ degrees become es doable though you have to stop and re wet it about once an hour.
:C
:C
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
