MEXICOWANDERER
Aug 21, 2019Explorer
The only mode I would utilize is the manual voltage adjustable one and for a bit less money I can get a Meanwell RSP 150 ampere unit. It loves a strong generator and there are 9 fixed chick-click-click voltage settings and a 12-hour timer...
For this PORTABLE battery CHARGER.
And voltage settings determined by a battery design engineer, and not a computer chip programmer in Uttar Pradesh India.
For AGM one setting maintains 14.40 volts exactly. There is a 16.00-volt current-limited circuit for equalization done correctly.
Every wire inside and there is a bundle of them is SILICONE tinned. And there are 9 Bournes TWENTY FIVE TURN pots in the event one of the voltage steps needs to be tweaked. This is an expensive labor-intensive effort that makes the BORG and Hyperwatt projects look like child's play. Yeah the controls are all Mil-Spec.
