BFL13
Dec 28, 2017Explorer II
Yes, just disconnect the batts (wires off neg post, not by using disconnect switch)and the converter will do all the "12v" work.
By leaving the positive post wires on, the slides , jacks etc that are battery direct will still have a path for the converter to run them. If you remove the batts entirely, you can clamp those pos wire terminals together (eg vice grip pliers) and get the path, but be careful not to let the clamp touch the frame (big sparks!)
If you leave soon to be dead batts on the converter, the converter might get overworked trying to charge them (not too sure about that, but why take a chance?)
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
