John_Joey
Dec 28, 2017Explorer
NEOK wrote:
I have two batteries that only show 11v on my multimeter. I have tried to charge them up but can't get them to read above 11 volts. Is it safe to use the RV occasionally plugged into AC power until I can replace the batteries in a couple of months?
Nobody can tell you if it's safe or not. That has to be your call on your comfort level. Now if it was me, I would do what you said.
The converter is designed to have what Wolf called a filter, and I would call a ballast. Taking them out of the system could damage your converter.
RV batteries like to cook so prior to plugging into 110 I would check the water level in them. You might find out you're way low giving you the 11v reading.
