BFL13
Dec 28, 2017Explorer II
NEOK wrote:
Thanks for the replies. I will remove the batteries and have both tested to see if one can still be charged. The camper won't be used until late spring or summer but I do need to get inside to do some work and would like to use the lights and maybe the furnace using ac power.
The furnace will use 12v power of course, along with the propane, but the 12v will come from the converter. Same for the 12v lights, although you can use a 120v "trouble light" when plugged in of course.
IMO, even if one batt is ok, you will need two eventually, and the usual idea is to make them the same age and model, so if that is the plan, you should not spend any money on the one "good" battery if there is one, since it will be an orphan in the Spring.
