rockhillmanor
Dec 29, 2017Explorer II
On 'most' RV's. You would have to check if yours is the same.
The fridge, and A/C, and co detector all need a constant 12v to them.
The fridge and A/C thermostats run off 12v.
(i.e. they run off your RV battery, not the shore power.)
If your coach battery has ow voltage your fridge and A/C will come on, but when they hit the temp set and shut off.....their thermostats can not turn back on again.
Detector has a 'low voltage alert'. If voltage drops from 12v they start beeping to alert you of low voltage.
