GoPackGo
Dec 30, 2017Explorer
Kayteg1 wrote:
It all depends.
Several times I had my camper park at home with no battery and had to move the slide. It will move on 40 amp converter.
Electric jacks will operate on converter one at the time, but will trip charger overload when central button is pushed.
Than when I hook up my truck and plug engine charging -it all works just fine with no battery in the camper.
Maybe the difference is that I have the 6-way leveling system . There is one pump for all the hydraulics. Lippert says it can momentarily pull more then 50 amps when retracting slides or jacks, but much less when extending them.
With this system I can't retract only one jack at a time. I can individually retract the 4 rears, one side, or the landing gear.
My converter/charger is a Progressive Dynamics 80 amp unit.
And as I stated, plugging into my truck was no help. The sustem required a functioning battery in order to work.
Like you said - it all depends.
