wa8yxm wrote:
Gee. my Progressive Dynamics INtella power does that.. After 20 hours of float it goes into a 15 mintue (Or so I'm told) Equalization cycle.. I have seen it do this.
Many good 3-stage converter/chargers have an equalization feature, most of them manually activated.
Do not confuse the anti-stratification periodic "equalize" feature of a float charger or converter with the "real" Equalize on the Vector.  Compare the Vector's with the Equalize on your Prosine 2.0 to see the difference.
BTW, I took out the noisy fan on mine and externally mounted the old fan off my busted Paramode converter instead.  It had more room for screws on the frame part.  Nice and quiet now.  I do notice how the fan speeds up when the charger is doing full amps.  Must be some clever connection in its brain between charging amps and fan speed besides just the actual temperature.
