westend
Sep 09, 2014Explorer
Use a ball bearing fan. A sleeve bearing fan will wear out quickly when oriented horizontally.
FWIW, I've lubricated dozens of muffin fans, sometimes having success. Usually, by the time I've mistreated and not maintained them, they may die. Your situation is just a poor piece of hardware, i.e. the original fan. I've had good luck with the Ever-cool fans. If it's too loud, lower the voltage, you'll still get plenty of air flow through a small case like that.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
