beemerphile1
Sep 09, 2014Explorer
It would be absurd to dismantle the charger, squirt some lube and put it back together rather than replace an under $10 fan.
Unfortunately I didn't write down the original fan. I had to put it back together to use it next week. Don't quote me but I think the original is a 'Xinruilian RDM6020S'. I Googled the original and found no specs on it.
It definitely is 20mm thick and I can't find them locally. The local electronics store only stocks 25mm and 15mm thick fans.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
