beemerphile1
Sep 09, 2014Explorer
VEC1093DBD replacement fan?
My Black and Decker VEC1093DBD charger fan acted up last winter.  In below freezing temperatures the fan squeals and takes a while to start running.  In warm weather it works fine.
I want to replace the fan before this winter. I took the original out and found it is a 60mm x 20mm fan. Does anyone have recommendations for a replacement?
I have read that the original has sleeve bearings but haven't been able to verify. I also don't know the CFM of the original. I would like to have equal to or more CFM in a ball bearing fan.
I found this one as a candidate;
Amazon 60mm X 20mm fan $8.33
The original is two wire and this replacement is three wire but it shouldn't matter.
I have read that some used an external fan but I would prefer to stay inside the case. An external fan would be complicated because the air intake and exit are in close proximity on the same side.
Recommendations?
Recommendations?
