Joe417
Jul 07, 2016Explorer
The brackets should work fine fastened to the side of the Fantastic fan, but I've never seen them installed with sheet metal screws. The housing is plastic. I'm not sure a sheet metal screw will stay tight in the plastic.
They come with machine screw, washers, and nuts. They are suppose to drill a hole and use a nut and washer. That requires 10 extra minutes and possibly a second person to hold the hardware from below while the person on the roof tightens it. I think your dealer saved a few cents in labor by not using machine screws.
I think I would replace those sheet metal screws with stainless machine screws.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
