BB_TX
Feb 28, 2015Nomad
The unvented units DO NOT put moisture inside the RV. Read up on how they actually work and you will find that they are sealed units that use a process to convert the moisture the a vapor, use cold water to condense it back to a liquid, and then drain it.
But. The unvented units do use a lot more water due to the condensing cycle. And they take longer to dry the clothes.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
