jrnymn7
Nov 01, 2014Explorer
MEXICOWANDERER wrote:
Those little chargers IMHO are garbage. The ones with separate TRANSFORMER and regulator circuit. Too many regulator failures. But with the regulator cut out of the circuit stick a 3 amp axial diode inline with the positive charge lead and the transformer gets tamed. Recheck voltage. If need suggests it add a second diode this time a shottky to further reduce voltage by .4 volt. Ideal is 13.3 to 13.6.
Mex, would this work the same if trying to lower/change the voltage output range of a power supply unit such as the meanwells, megawatts, or even my turnigy? For example, my turnigy has an a adjustable range of 13.6 - 18 volts. Could I change that to say 11.6 - 16 volts, or would it only limit the upper end of its output range? so, 13.6-16v?
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
