mchero
May 15, 2019Explorer
Soapy water over EVERY INCH of your propane lines.
If you cant find any leaks then you might have to plug the gas lines to stove, Water Heater, furnace(s), absorption fridge and such then pressure test the lines. If they are gas tight then it must be one of the appliances.
Don't forget the pressure regulator, they can sometimes leak as well as any rubber gas lines, e.g. lines from regulator to tanks and rubber gas hoses if you have a gas appliance in a slide.
Not fun but the only way your going to track down a leak.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
