profdant139
May 16, 2019Explorer III
Some great tips here -- thanks!! I did not know that a diaphragm leak does not blow bubbles -- so that is a great place to start -- new regulator. She does not smell propane inside the trailer, ever, so that tells us the leak is probably outside.
I had never heard of Oatey mega blue soap -- now I know what to look for!
And Doug, that is a very good point about the high pressure side ("upstream" of the regulator) and the low pressure side.
Phil, I am pretty sure it is not the threads in the tank, because the leak occurs regardless of which tank I am using. It would be odd if all of my tanks were afflicted with the same issue.
I will post an update, if and when I get this figured out.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
