pirlbeck
Apr 29, 2018Explorer
OK, it looks like the link above for info 1 is the one I need to use. As posted above my batteries are not a "true" deep cycle battery.
I spent some time looking around at the different charge profiles on this charge controller. Here is a list of the 8 battery presets.
AGM Spiral cel
Gel Victron deep discharge (1)
Gel Victron deep discharge (2) (This was the default setting and the one that is still selected)
Gel Victron long life (OPzV)
Lithium Iron Phosphate (LIFePo4)
PzS tubular plate traction (1)
PzS tubular plate traction (2)
PzS tubular plate traction (3)
Here are the settings for the Gel Victron Deep discharge (2) preset that I have selected.
Absorption voltage -14.40 V
Maximum absorption time - 6h 0m
Float voltage - 13.80 V
Equalization voltage -16.20 V
Automatic equalization - disabled
Manual equalization - this has a "START NOW" button.
It looks to me like this setting should be pretty close other then needing to turn equalization on.
Opinions????
Thanks!
AGM Spiral cel
Opinions????
Thanks!
