rvgrammady
Aug 22, 2014Explorer
I have one of these boxes that plug into my 120 plug inside the RV. I don't have two and I don't know where I would plug in the second or which side or group is on which circuit you are talking about.
The one I have has always stayed in the good area... so I really don't look at it all the time.
I'm just trying to get more savy since I now travel alone and there are a lot of things I'm in the process of learning.
I probably didn't make myself clear. I am talking about checking the
RV site 120v at the post where you plug in.. the 50 amp and 30 amp socket BEFORE I plug in.
But I guess the responses I get is that my surge protector will
meet that need. Mine does not have a read-out. it has blinking lights but if it turns off, there are no lights so I would not know what the problem was. It could be low or high voltage, reversed stuff etc.
I was thinking I should check before I plug in and then if it's OK then I can plug in. or if something was wrong I wouldn't plug in.
I don't want to blow up my surge protector thing as it was quite expensive.
Also, I was told to make sure I plug in with the circuit breakers off and after plugging in, turn the breakers on.
Tks, for your comments and information.
Dy
Northern Calif
Dy
Northern Calif
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
