kcmoedoe
Aug 23, 2014Explorer
camperpaul wrote:Still wouldn't tell you if the two phases were properly split. Also wouldn't tell if the two lines were properly connected to the outlet. Those meters would technically show 120 volts each if the neutral in the pedestal was hot and both hot sides were connected to the grounding block. Better than nothing, but not a good answer at all.ScottG wrote:camperpaul wrote:
This is the meter I use:
Most camping/RV stores carry it.
Could you explain to the OP how she is going to check a 50A 240V outlet with that device?
The 50Amp 240Volt power is split into two 120 Volt "phases" and one of these meters would be used on each phase.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
