rvgrammady's avatar
rvgrammady
voltage meter or how to ck 50 amp at rv site
I was told I need to check my elect connection before I plug into the
RV campsite electricity. I have 50 amp and sometimes use a 50/30 2 foot converter (50 amp one end 30 amp other end) from Camping World. and I have a 30 amp big 25' cord also from Camping World.
I have a TRC 34560 Surge Guard 50 amp Hardwired installed.
So, I will be traveling to Mexico. So many people say it doesn't
matter where you go you should check you plug in before you plug in.
They say get a volt(age) meter and check the hook-up.
OK so what do I buy, how do I check it. Don't know anything about this.
I am now a single senior female. I didn't do the hook-ups before three years ago, now that I am alone.. I don't know if I need to do this or
how to do this or what equipment I should buy. I haven't done it before. I did have my elect shut off and then it reset later, but that must have be a surge or low elect as I had been plugged in for 3 days and everything was OK. So I
guess the surge thing worked. But if it's bad at the site maybe when I plug in, it could fry the surge thing. I don't know what to do.
I checked Amazon but there are all kinds of meters costing from $5 to
$200 ...
Help... you are my go to resource... Thanks for the help.
Dy
Northern Calif
  • ScottG wrote:
    camperpaul wrote:
    This is the meter I use:
    Most camping/RV stores carry it.
    Could you explain to the OP how she is going to check a 50A 240V outlet with that device?
    The 50Amp 240Volt power is split into two 120 Volt "phases" and one of these meters would be used on each phase.
  • Your surge guard will do the work for you. If the voltage is to low, it will not allow power to the coach. If the voltage is to high, it will not allow power to the coach. If there are any other problems with the power such as an open ground, it will not allow power to the coach.
    We go to Mexico every year and allow our surge guard to protect the coach.
  • That surge guard has a remote read out yes? Just use it.
    No power should connect to your RV unless Surge guard verifies all is good.
    So nothing to check as you are fully protected.
    Now what to do if surge guard will not connect.... depends on what you expect.
Having RV issues? Connect with others who have been in your shoes.24,240 PostsLatest Activity: May 04, 2025
